dscp
gre tunnel
Sets the GRE tunnel‘s DSCP / 802.1q priority value from encapsulated packets to the outer packet IPv4 header.
This option is disabled by default.
Syntax
dscp [<0-63>|reflect]
Parameters
dscp <0-63> Specifies the DSCP 802.1q priority value for outer packets from 0 - 63. The default is 1.
dscp reflect Copies the DSCP 802.1q value from inner packets
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#dscp 20
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#show context
 gre tunnel testGRETunnel
  dscp 20
Related Commands
no Removes the GRE tunnel settings based on the parameters passed
